FZR600R engine vibration
dougs
Post by dougs »
hi, can any one help with this little problem? i have an engine vibration that gets worse with the higher revs, is it a normal thing with the fox eye or is there something particular i need to look for?
it is not severe but i have noticed it, i have to back off the tank when riding and my wife has also noticed a problem with the pillion pegs, no real problem with the bars though!
FZR600R '94'
Bluespot calipers
Wavey front discs
R6 front mastercylnder
Mild steel chain adjusters
Art can with removable baffle
Carbon fiber chain guard
Glass fiber rear seat-hump
Re: FZR600R engine vibration
Doug,
Ok lets go with the obvious but frequently overlooked basics:-
Engine to frame mounting bolts all up to correct torque (as per the book you did get one for your new toy ?)
swingarm pivot bolt ?
frame loops ?
rear wheel axle ?
and last but not least chain adjusters and sprocket nuts.
some of these are counter intuitvie but non the less play funny games with the "feel" of the bike.
having checked that lot the we get a bit more worried about engine internals but past experience tells me it is some thing less drastic
dougs
Post by dougs »
thanks, i will check the mounting bolts, it wont be anything not connected with the engine e.g. swingarm, wheel bearings, chain etc as its connected to revs only (pull the clutch at speed and it goes smooth as a baby's @r$e) there is no issue with the handling as that is better than great, i was wondering if it could be carb related as its a little lumpy when i open her up?
update
i have had a play with the carb sync and it's def. better so im going to take her to the garage and have her tuned up :banana:
FZR600R '94'
Bluespot calipers
Wavey front discs
dougs
Post by dougs »
ok problem solved i have made a mamometer and balenced the carbs which has transformed the bike it now runs like a dream thanks to the Wiki i was able to tue her up a treat thanks :headbang:
FZR600R '94'
Bluespot calipers
Wavey front discs
dougs wrote:ok problem solved i have made a mamometer and balenced the carbs which has transformed the bike it now runs like a dream thanks to the Wiki i was able to tue her up a treat thanks :headbang:
D,
Ahh another satisfied customer, :thumbsup:
I always thought a mamometer was a thing for measuring tits
Yeh it was a typo for manometer but sorry could not resist LoL
dougs
Post by dougs »
yet another problem solved finally got the last of the rattles out of the engine it turns out it will only run well on 97 octane NOT 95 so she likes the expensive stuff and now runs really smooth so anyone with the same problem, first get the carbs synced and then check the fuel is right octane
FZR600R '94'
Bluespot calipers
Wavey front discs
Kylemil21
Post by Kylemil21 »
Damn nice. do you get 97 out of pump gas? highest we have where i live is 93 :P
99 FZR600, Finally completing my project, Still a long way to go. but its presentable! :]
Live to ride
From Springfield Missouri
