front pitbull stand
McFizzer
Level 3.0
Level 3.0
front pitbull stand
Post by McFizzer »
Okay so FINALLY I got my front n rear pitbull stands from the PO of my bike...after buying a rear stand already... ANYWAY
Having the bike on the rear I decided to use the front. The pin fits the bottom fine although the horn is in the way n has to be removed prior. But my question is, when I go to use the front, it pushes up just under the light (I have a 92) I noticed there is a small crack there from when he used it I guess.
Do I have to remove the front fairing to use it? It appears this way at the current time
1992 FZR 1000
sweekster
Re: front pitbull stand
Post by sweekster »
Mine is a TRex and i noticed the front fairing does kind of rest on it. Mine was cracked prior to mine getting the stand though. Otherwise it's fine for me.
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
You might not have the right pin. Pit Bull sells the pins for the bike separately. Mine doesn't hit my fairing on my GSXR.
darrin
McFizzer
Level 3.0
Level 3.0
Post by McFizzer »
Duane. Do you have a problem with how your horn is mounted? Its an easy fix just need to get some aluminum but my sits in between the brake line crossover n the frame and prevents access to the hole on the bottom, just un screw n I'm fine..
Rage, I'll call pitbull tomorrow n see if there's a way of identify the right pin n if so order a new one. I more or less ASSumed that its the right pin being the PO was using them..
1992 FZR 1000
sweekster
Post by sweekster »
Gees it's been a year since I got it. I think I may have had to move it up out of the way. It didn't take much to get it squared away though.
