new bike
skillz
new bike
Post by skillz »
ok so yesterday i decided to clean up my 93 fzr600 i had just bought the bke a moth ago and didnt realize the bike was absoultely dry no coolant no brake fluid so now i need help on chooses what kind of motor oil i should use what kind of brake fluid and what kind of coolant when i go to my local bike shop sometime this week thanks you pictures and links would help
Re: new bike
[quote="skillz"]ok so yesterday i decided to clean up my 93 fzr600 i had just bought the bke a moth ago and didnt realize the bike was absoultely dry no coolant no brake fluid so now i need help on chooses what kind of motor oil i should use what kind of brake fluid and what kind of coolant wh
Since I am in the UK I can only point you to coolant that I have used since it first came out and that is "engine ice" used it in the tropics and in the cold worked well.
Oil I am sure the guys back home will tell you what they swear by or swear at in the way of oil & and brake fluid.
ONE big NO NO is car oils with addatives that screw out clutch corks .
Brutal Tooth
Re: new bike
Post by Brutal Tooth »
I use all the basic oils and coolents out there. I use a reg. all purpose (for cars too) antifreeze, DOT 3 brake fluid (yes, same for cars as well), and motorcycle ooil found at any parts store. Sure you can use a fancy version of all of this, but the only thing fancey I would get would be different motor oil if I had a newer bike.
