rear wheel play
FZR AL
rear wheel play
Post by FZR AL »
Ok guys need some help , there is some play on the rear wheel of my fzr600 3he 89-90 model (twin round headlight) there is 3-4mm play in the rear wheel, is this acceptable or is it time for new bearings,or is it cush drive rubbers,
I have tried to look in the manual for the sizes of the bearings but i can not find anything on the sizes, also do they still do the 2 rubber seal covers ?
cheers al
If all else fails (hit it with a big hammer)
Re: rear wheel play
al the info you are after is in the WIKI when you find the bearing then just add -2rs after it and it will have 2 rubber shields ie 6303-2rs
del_barry
Re: rear wheel play
Post by del_barry »
i just had to replace my rear bearings. very alarming once i got the wheel off
the bearing was in very very bad shape
but i paid $82 for bearings and getting them pressed in total
better than the $225 yamaha quoted me
1994 Yamaha FZR600
Re: rear wheel play
del_barry wrote:time for new bearings
DB,
I assume that 82 bucks is for all 3 bearings associated with the rear wheel ?
del_barry
Re: rear wheel play
Post by del_barry »
yes. there is a local bearing shop in town that sold me the bearings for $12
and the one local bike shop that is open monday charged $70 for 1 hour labor
my outer right (iirc) was torn apart and they had to weld a bolt inside the outer ring to get it out
1994 Yamaha FZR600
