I've got a spare FZR engine I'm gonna rebuild, the gasket kit i have in mind is this one:
http://www.denniskirk.com/jsp/product_c ... &mmyId=666
has anyone used this kit and liked/disliked it. If you used a different kit can you link it.
also any potholes that i should be wary of would be appreciated.
Thanks David M.
Gasket for Engine Rebuild
Re: Gasket for Engine Rebuild
somene is selling a gasket kit on the boards for like, $70. lemme see if ican't find the thread
Upgrades:
89 FZR 400
Custom Paintjob
600 plastics.
06 - R6 Shock
FZR600 Motor
Soon to be:
Broke........
Custom Paintjob
600 plastics.
06 - R6 Shock
FZR600 Motor
Soon to be:
Broke........
