standard size piston rings
does anybody know where to get the standard size piston rings for a 94 fzr 1000 exup? i know bike bandit has them but really hate paying 70 bucks for one set of rings. any idea's on where to go?
Re: standard size piston rings
ebay, dealership idk from what i've heard if you want rings you will just have to pony up the cashcoreo19 wrote:does anybody know where to get the standard size piston rings for a 94 fzr 1000 exup? i know bike bandit has them but really hate paying 70 bucks for one set of rings. any idea's on where to go?
Upgrades:
bluesbreaker45
If you're on the cheap you may try to buy a used set of pistons, rings, and cylinders.
This is what I would do if I was on a tight budget- call me crazy.
Come see me and my FZR1000 at US60 Raceway in Hardinsburg, KY on Saturday evenings
1994 Yamaha FZR1000- Stock Wheelbase
Best 1/8 mile ET to date- 6.463 @ 110.97 with 1.58 60 ft
Keihin 41mm FCR carburetors
YZF750 Cam Shafts
YZF750 6-Speed Transmission
Falicon Billet Clutch Basket
KG Heavy-Duty Springs with OEM Fibers & Steels (Ask me why)
Hindle competition plus exhaust system (Stainless Steel header with carbon fiber canister)
DID gold O-Ring Chain-520 conversion (15-47 Gearing)
Harlan Engineering Programmable Shift Light
Daytona Sensors WEGO III A/F data logger
IGNITECH Programmable TCI
Ohlins Rear Shock
Pirelli Diablo Corsa III tires
Spiegler Stainless Steeel Clutch and Brake lines
EBC HH Brake Pads
Integrated tail light
YZF750 Cam Shafts
Ohlins Rear Shock
EBC HH Brake Pads
