R6 swingarm length
R6 swingarm length
For those who have done an R6 swingarm swap or tried it... I want to know what the length of the arm is from the center of the pivot to the center of the axle. Thamks in advance.
Re: R6 swingarm length
I found my answer after an hour's worth of searching. The search function is very limiting. You can't lookup "R6" because you need at least 3 letters. I also came up with "The following words in your search query were ignored because they are too common words:" SWINGARM was one of my too common words. The answer I found is... 22.75" and a min adjusted length of 21".
Yeah, I was gonna say..out near the end of the axle travel you have 590mm(23.2 inch) on an '08 R6 swingarm.
