electrical issues, it keeps frying my ignition wires
rehaume
100+ Posts
100+ Posts
Post by rehaume »
I am having issues with my bike ground out and frying my ignition wires.... I just paid 250.00 to get them fixed, I went to go pick up the bike and my mechanic re-wired all the ignition wires and i had the fzr sitting at an idle while we were talking and 10-15 mins go by of it running and i go to leave and before i even get a mile away the wires to the ignition are fried again. does anyone know what this could be? when i say fried i mean they were smoking and melted the wires. he re wired the blinkers also but is what is weird is it was running fine untill i put it in gear and go, any ideas?
Wichita, KS
95' FZR600
88' FZR400 with YZF 600 Motor
yahoo msg: swingline1021
FlyByU
Re: electrical issues, it keeps frying my ignition wires
Post by FlyByU »
Bad ground wire somewhere. Check the negative battery cable and make sure it's secure at both ends. Otherwise, you have a bad ground or maybe a wire is bare and is shorting out along the frame somewhere.
1987 FZR750RT- Has a 1990 FZR1000 engine and front end, 40mm Keihin flatslide carbs w/ K&N stage 3 pod filters, Vance & Hines Powerpack, D&D polished full exhaust, Polished frame and swingarm, PM Chicane wheels, SS Braided front brake lines, Red LP Speedscreen.
reelrazor
Wrench
Wrench
Post by reelrazor »
Wires to THE ignition CIRCUIT...as in...wires from the TCI unit that power the coils??
Or "ignition" switch....as in key switch?
Has the simple check of your voltage regulator/rectifier been done? You may have a serious overcharging issue..or you may have AC electricity flowing in your system
