Im about to buy a set of front callipers from a 3tj model but the guys says they have no pad pins or springs...what other fzr model pins etc can i use?...im in the uk so uk spec bikes would be good
shugsi wrote:Im about to buy a set of front callipers from a 3tj model but the guys says they have no pad pins or springs...what other fzr model pins etc can i use?...im in the uk so uk spec bikes would be good
Shugsi
Shugsi,
Please put you location in your profile for future referrence
The only difference I am aware of on calipers amongst 400's is the rear set up which have a different fixing hole space.
As to the springs not sure but pins are easy enough to get made.
3tj were made from 89 onwards and imported as greybikes, they were officially imported to the UK (not sure about the US but don't think so) as the 4dx from 92 onwards and are basically the same thing (unrestricted) so any 89 part or newer should be interchangeable unless you've got a 3en2 which was also made in 89 although the 3en2 has the smaller forks, not sure of the size but the 3tj's are 43mm
hope this hasn't muddied the water further
Shugsi
Shugs,
Most Yamaha calipers are the same, the trick is too look up on the micro fiche the part number and then put that number in the part finder and see what other models use it .
Sorry to not give you answer but at least you now know how to get it.
