bike won't start
bike won't start
Hey everyone, need some help..I have a 97 Fzr 600.. installed a new scorpion battery, new start/kill switch.... with the key on, the oil light comes on as soon as the start button is pushed... I also get a click at one of the relays on the left side...no fuses are blown??? any input will be of help...
Re: bike won't start
good luck with it, hope we helped you a bit in the chat, or at the very least bombarded you with too much information!
I did that.
Thanks guys! Found the prob...The starter solenoid..Hooked up 2 leads from a toggle switch down to solenoid,turned the red switch down to run and flipped the toggle switch..Fired right up...I will have to get another key/ignition switch, it's done...
