nuetral issues
- dunebuggyq
nuetral issues
I have a 1991 FZR 600 that has issues with going into nuetral. It usually just skips by it and goes into first or second. Everything else gear wise shifts great so i am at a loss of thoughts. Thank you for any help
- dunebuggyq
Re: nuetral issues
oil level is good and clutch adjustment seems fine it catches about half way out
- kilika2
- 1000+ Posts
Re: nuetral issues
I did a wiki search and there was a guy that was having the same problem, I don't have the link now cause I'm at work and I found it on the home computer. But as I recall it was basically everything that 95 told you too.
Chris.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
- dunebuggyq
Re: nuetral issues
If you coud send me the link i would greatly appreciate it.
- kilika2
- 1000+ Posts
Re: nuetral issues
I'll try to copy the link, I'm using my ps3 and the copy/paste is weird. If it doesn't work search gear selection problem at the top of this screen and it will bring it right up.
viewtopic.php?f=7&t=3712&start=0&hilit=neutral+problems
There we go. Scroll down a bit the later stuff is more for you. At the beginning the guy is having the opposite problem. Hope this helps.
Chris
Chris
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
- dunebuggyq
Re: nuetral issues
thanks for all the help
- dunebuggyq
Re: nuetral issues
Just an update guys it was the detent lever that was broken causing my problems just replaced it with one from Factory Pro works great now.
