Forks
Yamster
Donating Member
Donating Member
Forks
Post by Yamster »
The 3HE forks,will they fit on a 400?
I am sure i read that they are a straight swop,but that the spacers and some other things are slightly different.
If anyone could enlighten me i would be most grateful.
A lad has just asked me,and i dont want to sell anything that cannot be used.
Thanks in advance. :cheers:
Re: Forks
Yamster wrote:The 3HE forks,will they fit on a 400?
Yam.
I believe they can be BUT that said you have to know which 400 england has at least 3 models of 400, 1WG, 3TJ, 2TK and damned if I know which one does what.
Suggest you get yer pal to measure his old fork diam & check if your 3HE matches
cad600
Re: Forks
Post by cad600 »
I think the 3HE (FZR600) forks are direct bolt on for the 1WG (FZR400). But better to take a measurement first. What I do know is that the fork diameters are the same between these models. The 3TJ uses the same fork diameter as the 99-02 R6. The hearsay is that you can put the R6 forks into 3TJ yokes too. But don't quote me on any of this.
sweekster
Re: Forks
Post by sweekster »
cad600 wrote:I think the 3HE (FZR600) forks are direct bolt on for the 1WG (FZR400). But better to take a measurement first. What I do know is that the fork diameters are the same between these models.
So don't sue me because I just quoted you on this stuff... :rofl:
I kid I kid...I think you may be right though (my memory is crap these days). Nate can probably confirm it.
fzrbrandon
Level 7.5
Level 7.5
Re: Forks
Post by fzrbrandon »
The forks are indeed directly swappable between the 3HE 600 and 1WG 400 as far as stanchion diameter, stem length, etc. goes. For a 2-pot swap, I THINK the '89 3HE 600 are bolt to the '88 - '89 1WG 400 (without having to swap rotors). However, for a 4-pot swap, I THINK the '90+ 3HE 600 fork lowers have a slightly different caliper boss offset than the '90 1WG 400 lowers (since I have both, I REALLY need to confirm this!). In that case you would need to swap the rotors also (maybe calipers also?). It's a little fuzzy - hence the double "I THINK"! LOL! But those are the issues you need to be careful of.
Sorry I don't have anything more concrete. :whistle
Image Image
http://www.fzrbrandon.com
cad600
Re: Forks
Post by cad600 »
sweekster wrote:So don't sue me because I just quoted you on this stuff... :rofl:
I know nothing......... he says in a Hogan's Heros Sultz voice.
