FZR 1000
vlakvarkbeer
FZR 1000
Post by vlakvarkbeer »
Hi there again , thanks for the info. Another problem how do u get gasolene in the engine oil is there a explanation for that. Thanks
sbutler
Re: FZR 1000
Post by sbutler »
Carbs are overfilling float leval is wrong & leaking fuel into the engine..Common problem.
vlakvarkbeer
Re: FZR 1000
Can the float leval just set itself deu to wat pump presure .
Re: FZR 1000
sbutler wrote:Carbs are overfilling float leval is wrong & leaking fuel into the engine..Common problem.
Check the float valve seat for wear on the valve rubber<?> seat tip
chefen2006
Level 3.5
Level 3.5
Re: FZR 1000
Post by chefen2006 »
eehhh if the float level is too high or the needle is leaking,exes fuel will run out of the carbs and splash out under the bike,some of it would pour into the engine. And also,the bike would misfire on the cylinder(s) that`s got the bad carb. Ask me how i know......
cecorri
Re: FZR 1000
Post by cecorri »
Dont run the motor more than absolutely necessary and make sure you change the oil immediately after finding the problem !! Gasoline greatly reduces the lubricity of oil and you can kill a motor in just a few hundred miles with oil that has been contaminated by gasoline !!
CHANGE THAT OIL !!
