front turn signal/inspection question
has anyone in mass had a problem with aftermarket turn signals in the front not having the running light always on and only being a turn signal flasher the ones i ordered are just single filament flashers i can probally switch the socket in them to a dual filament but if i don't have to why bother
Re: front turn signal/inspection question
If they are LED, you will have to get the wire conversion to allow you to use them as running lights. Although, http://www.superbrightleds.com sells the 1157 led bulbs that can work with standard three wire terminals. If they are standard bulbs, you need to look at the wiring. If it has three wires then just swap the bulb. If it only has two wires, you will need the wire conversion kit again. Basically, the kit splits the power wire into to leads to be plugged into the wire harness. This allows power to run to the light for running lights then when the switch is used, the other wire from the flasher relay takes over. You should be able to get them at any bike shop.
