3.5x18 comes stock with a 130x70x18
sooooo, anyone know if a 150x60x18 fit? i know a guy who needs a tire, and i just so happen to have one! but not sure if it is going to fit. not easy finding Seca mods!
95 yamaha seca 2 rear tire
I did that.
Re: 95 yamaha seca 2 rear tire
My 89 FZR came with the 3.5" rim and I had a 150 on it. I know the engine is very similar to the FZR and the rear wheel seems similar so I think it would work. The only issue I can see is if the sprocket carrier on the rear has a different offset than the FZR which may cause the chain to rub on the tire.
I would also bet that a shop will not like to attempt to put the tire on the rim.
