Front brake bleeding problem
When i take off one of the banjo fittings in the front and pinch it, then pump the lever, all i can feel is a little pulsing. There is nowhere near enough pressure to actually squirt fluid out from between my fingers. I just installed a MC rebuild kit and its still doing it. Any ideas?
Re: Front brake bleeding problem
air in the system?
SOLD
SOLD
First off what you are doing by trying to pump brake fluid thro your skin is VERY bad for your health. !!!saleenvp wrote:When i take off one of the banjo fittings in the front and pinch it, then pump the lever, all i can feel is a little pulsing. There is nowhere near enough pressure to actually squirt fluid out from between my fingers. I just installed a MC rebuild kit and its still doing it. Any ideas?
When you say you did a MC rebuild did you replace the pump rod that the seals fit on .?
Repeating that as a Mantra is not going to clean the passage ways in the M/C push rod95FZR600 wrote:Mighty vac is all I can say!
