Now that ive fininshed my track days for the year I wanted to ask about the gearbox. My gearbox is generally sloppy and clunky, i cant clutchless upshift reliable and occasionally it will pop out of gear (mostly 3rd or 4th)
If I wanted to fix this is it likely to be as easy as just putting new shift forks in, or would it be best to strip it down, to see what bits are worn. Anyone have any tip to share?
Thanks
Steve
Transmission Mission
Re: Transmission Mission
lean it all the way over and take off the oil pan and check the forks out. I think the forks can be changed without splitting cases but if its gears u will have to split the cases
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
