yzf throttle cable routing
im tring to put my carbs on and i wanna get the throttle cables on first and i was wondering how others that did the yzf engine swap ran there cables i was thinking across in front of the forks then under the main frame between the forks and engine rails over the top of the engine. it seems like because of the length going threw the frame left tomuch slack in front.
Re: yzf throttle cable routing
That is how I did mine. The cables are going to be long and in the way no matter how you route them.
- shredex
thats how I had to do mine on the yzf....I didnt look to see how they were orginaly routed.
I had to route the around the right fork and steering stem, then over the radiator and threw to the carbs
i went around both forks and under the frame . on my fzr its between the right fork and steering stem and threw the hole in the frame but theres way tomuch slack for that so i guess i was thinking like everyone else thanks for the help
