Ok, I am getting a set of forks from Target30 and had a couple questions:
1: Removal looks pretty straight forward but are there any tricks to installing them to make sure they are straight and lined up correctly so I don't get a pull or weird tire wear? The manual just says basically reverse order of removal. I have never had them out so I didn't know if there were any type of alignment marks or anything.
2: Down the road when I decide on different springs can I just replace the springs and oil without completely pulling everything apart if the seals are not leaking?
Thanks again for all the help.
Front Fork Install Question
92 FZR600
Dual Headlight Upper Swap
Clear Taillight w/LED Bulbs
More To Come
More To Come
- Huckleberry
Re: Front Fork Install Question
yep just put them on there reverse order that they came off. Grease the bearings up good and make sure your dust seals ar on. torque to spec and ride.
I am just replaceing the forks themsleves, not the forks with triples if that makes a differance.
92 FZR600
More To Come
More To Come
It should not make a lot of difference. The axle will only go in one way which will align the bottom of the forks (for the most part) and you should set the height of the forks in the triple to be the same using the clip-on. Just install one side at a time, get them level, then install the axle.tkclow wrote:I am just replaceing the forks themsleves, not the forks with triples if that makes a differance.
But don't be surprised if the triple is a little tweaked and you need a rubber mallet to get the fork in and out.
OK, sounds easy enough. Thanks guys
92 FZR600
More To Come
More To Come
