this is what it looked like when i took it apart
so I went out and found a new engine,
the engine looked good except for the drive sprocket, it had an awful lot of play, after removing the cover i found that there was a round spacer poorly welded to the drive shaft acting like a stop for the sprocket (it looked like it took some beating from the chain).
after finally getting the spacer off i found that there was no threads on the shaft...
that is my problem, any input on how to fix that problem besides replacing the shaft?
I was thinking about trying to use a die to re thread the shaft, but then the lock nut would have to have a smaller diameter as i can slide the nut on the shaft as it is...
any input would be greatly appreciated
-Thanks
Annette
