Is there a list that I am missing on which calipers are a direct bolt-on for my late model('96-four pot caliper) FZR?
can anyone provide one (R6? which years?)?
Caliper upgrade?? which?
Re: Caliper upgrade?? which?
Any R6/R1 pre radial mount. The gold spot calipers were better as the pistons were a composite material that dispersed heat better keeping brake fade to a minimum.
- shredex
as TK said...you can use yzf600 calipers as well.
i forgot what year R1 went to radial mount...i think 02...so 99-01 R1 calipers bolt on and 99-?? R6 bolt on
Thank you, TK. That's what I thought but wanted expert info!!thatkid wrote:Any R6/R1 pre radial mount. The gold spot calipers were better as the pistons were a composite material that dispersed heat better keeping brake fade to a minimum.
I hear that the master cylinder is what is the biggest part of the upgrade with the R6 calipers. Of course, they help too.
16x18mm Radial Master Cylinder along with r6/r1/fz1/yzf (blue/gold/silver spots) calipers will be the best upgrade you can do for the fzr. I've also heard the YZF750/FZR1000 6 pot calipers will fit as well but you would need a 19x18mm radial master to take proper advantage.
