Hello from a new fzr lover
FZR400 Forum
buzzawak
Post by buzzawak »
Hi All,
I have recently got off Ebay a 1988-1wg/1989-3EN2 in a sad condition which I will be fixing up as money and time allows. Well the engine and frame is 88 and all the rest seems to be bolted on from a 3en2.
I am in Australia and its a Japanese import. I was hoping some of you more knowledgeable owners could shed some light on a few issues I am having.
1) I have managed to download a number of manuals for some of the Fzr flavors but cant find a 1WG manual.
Would anyone have a copy available?
2) The many manuals I have read describe the same procedure to set the float level on the fuel bowl of the carburetors. Which is measuring a specific distance down for the "float Chamber line"
My problem is I do not have a "Float chamber line" marked on the base of me carburetorsImage
I think that's it for the moment.
Thank you for reading my post
Michael
tkclow
Level 5.5
Level 5.5
Re: Hello from a new fzr lover
Post by tkclow »
Welcome aboard :cheers:
92 FZR600
Dual Headlight Upper Swap
Clear Taillight w/LED Bulbs
More To Come
Dragon
Level 2.5
Level 2.5
Post by Dragon »
Welcome!
Someone should be able to help you out.
Check the WIKI, and see if your question isn't answered there. :headbang:
Pics of your bike would be awesome too!!
:yutugh2:
buzzawak wrote:Hi All,
Michael
Michael,
Welcome aboard, there are few members in Oz & NZ so you need to add your location in your profile saves someone telling you about a great shop in Pasadena.
The setting up of FZR carbs is not like other Mikuni's & yes our WIKI is the place to look for tech stuff for sure (not only FZR but general engineering to do with modifying bikes.)
Things to do with any bike you just bought:-
Change all Fluids
clean & inspect spark plugs (our are down a deep hole so you need to blow out the crap in that hole BEFORE removing plugs )
Check you Voltage regulator (under LH seat panel (when seated on bike)
If it is a tin can full of rubber remove it and addd anew version heavy finned type (R1 R6) as the originals tend to burn out at the drop of a hat and take out the wiring loom & TDI (black box ignition, our bikes DO NOT have CDI's)
Check swing arm, wheel bearings , steering bearings, tyres & Brakes
That should keep you busy for an hour or two :-}
buzzawak
Post by buzzawak »
Tkclow
Dragon
Yamaha George
Thank you for the welcome
I have read most of the wiki ( cant find the info about the carbies there)
George thank for the advice, I have covered most of the stuff you mentioned.
Thanks again
buzzawak wrote:Hi,
Tkclow
Dragon
Yamaha George
Thanks again
B,
it is under the how-to's on the tech book & links page (you will find all sorts of goodies there , I know I put adlot of them there LoL)
http://fzronline.com/wiki/doku.php?id=carburetor_page
buzzawak
Post by buzzawak »
Hi George,
Sorry but I cant find the information I'am after. I have looked at all the how to stuff.
I am looking for info on how to set the float level when you dont have a "float Chamber mark"
on your carbies.
Thanks
95FZR600
Post by 95FZR600 »
Welcome! Be sure to check out the Chat area. :thumbsup:
Dragon
Level 2.5
Level 2.5
Post by Dragon »
buzzawak wrote:Hi George,
on your carbies.
Thanks
I think you have to measure from the highest point on the floats to the base of the carb. Don't think there's a mark on the float chambers for measuring the heights. Hopes this helps! Good luck!
buzzawak
Post by buzzawak »
Dragon wrote: I think you have to measure from the highest point on the floats to the base of the carb. Don't think there's a mark on the float chambers for measuring the heights. Hopes this helps! Good luck!
Hi Dragon, The picture shows the procrdure listed in all the FZR manuals. As you can see I dont not have the "Float level mark" on my carbies.
Dragon
Level 2.5
Level 2.5
Post by Dragon »
Sorry, I have never used this method of setting my float heights. You probably have a different type of carbs, than what's on my fizz. Someone else may be able to help with this..... IDK
