steering stem bearings
allanturtle
does anyone know the japan number on the taperd bearings for a 93 fzr600 steering neck, i have the top bearing which is 32005JR but i dont have the bottom one. thanks guys! i think i read somewhere that the bottom bearing is a Japan 32006 is this correct? i just wanted to make sure.thanks
- shredex
Re: steering stem bearings
you can get a brand new set of the bearings off ebay for like $30...check ebay...
and if I remember correctly, the top bearing is the same as the lower bearing...
allanturtle
ya i saw them on ebay but i was going to call around and try to find the bearing local. i believe the top and bottom are 2 diffrent sizes. they have 2 diffrent part numbers and the top bearing i have is too small to go down the entire shaft
- shredex
is that by pushing it with your fingers?
the lower bearing is pressed in using one of them 2 ton presses...you cant get the bearing off without a press as well..
or at least this is how the bearing was on the yzf600 triple/r1 triple/and fzr triple that i had was
if you have a digital gauge tool, then you can measure the inside of the bearing and the outide of the stem
The top bearing has a smaller dia. inside hole.
- shredex
go onto bike bandit and check the schmatic for the part number....ill see if I can find it
32005x and 32006
The inside and outside diameters are different between them.
allanturtle
ok great thanks. i read somewhere else that those were the number on the bearings but i wanted to make sure before i went off calling around looking for them. i actually just ending up ordering the kit for like 30 something $..thanks for all the help guys
