The best tire size combination on the FZR-600 ?
Lasse
Post by Lasse »
Hi ! :banjoman
I'm in the progress to buy new tires for my bike and want to know the best
tire size combination , Front <--> Rear
Yamaha FZR-600 ( 1990 ) OEM tire size :
* Front : 110/70*17"
* Rear : 130/70*18"
Present size on my bike :
* Front : 120/60*17"
* Rear : 150/70*18"
HELP !
IDK
// Lasse from SWEDEN.
cad600
Re: The best tire size combination on the FZR-600 ?
Post by cad600 »
What front rim are you running. A 120 really shouldn't go on a stock FZR (US '89 - '99, Everyone else '89 - '95) rim. I'm not sure what tire selection you have over there, but in the US your best bet would be a 110 70 VR17 up front and a 150 60 VR18 out back if your running stock rims. If you do a YZF swingarm/rim swap (foxeye FZR) you can easily run a 160 60 VR17 out back. Same thing for the front, if you change to a YZF or R6 front end, you can change to a 120 70 VR17. Hope this helps.
Lasse
Post by Lasse »
cad600 wrote: What front rim are you running ?
A 120 really shouldn't go on a stock FZR rim.
I think your best bet would be a 110/70 * 17" up front and a 150/60 * 18" out back if your running stock rims.
I'm running the stock rims for the 1990 model year !
Front : 3,0" * 17"
Rear : 3,5" * 18"
cad600
Post by cad600 »
I know the rear is OK and a Bridgestone BT14 150 60 18 will fit. I was running that on mine. As for the front, I don't know. I was running a 110 70 17 matching Bridgestone. And liked it just fine.
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
I've heard the best thing to do is stick with stock sizing for front and rear for quicker turning. I have a 120 on the front cause that's what the guy recommended at the bike store, but then again he knew very little about the FZR. I have the 150/60/18 on the rear and it seems to work well.
Since I have a YZF swingarm waiting to go on, I'll probably stick with the 150 rear, but go back to the 110 front.
Lasse
Post by Lasse »
ragedigital wrote: I've heard the best thing to do is stick with stock sizing for front and rear for quicker turning.
Is modern rubber available for the 18" rear wheel ?
According to some, this is the weak link on the 600.
Even though the 600 came with a wider rim than many 1000's at the time (4.0 inches), and was among the first sport bikes to come with radial rubber mounted, the back wheel is still a very industry non-standard 18x4 inch.
There are still several choices for rubber (both bias ply and radials) on the 600.
On the front, it seems that most people opt for the 110/70/17 size to preserve the quick steering nature of the bike.
A 120 will fit, but slows things down noticeably.
A 140 comes stock on the rear, but a 150 will fit with no problems, and the most popular size to date is a 150/60ZR18.
Brands are very subjective.
The most common tires that I have seen are:
Bridgestone: BT56SS in three sizes for the front, stock 110/70ZR17, and the oversize 120/70ZR17 and 120/60ZR17. They also make a 150/60ZR18 for the rear. This is a very good tire with good grip and mileage. They also make a BT58 race front in the 120/70ZR17 size.
Dunlop: K591 Bias Ply tire in the 110/80V17 size and the belted version in the 120/70VB17 size. These aren’t the greatest tires, but they are cheap and will perform for the average rider.
D207 Front in the 120/60ZR17 and 120/70ZR17 size. This is an excellent tire, in my opinion it has the most grip for a street tire (behind the Michelin Pilot and Dunlop D207 GP). This is what I run up front.
Sportmax I Front in the 110/60ZR17 front and 140/60ZR18 rear. This is an average tire will decent grip and good mileage. This is what I use in for the rear.
Metzler: MEZ1 in the 110/70ZR17 and 120/70ZR17 in both race and street compounds. They also make a 150/60ZR18 Rear. I don’t know the first thing about Metzler (except they used to make good hard compound slicks for the FZR) so I won’t comment on these. If I get some info from someone, I will update the Faq.
Michelin makes a Macadam rear, and a race compound front.
Regardless of your tire choice, remember that with such a lightweight/low power bike, you should not be spinning the rear or pushing the front too often. If you are, you need to evaluate how old your tires are, and what your suspension is doing.
I normally get at least 2k miles out of a front tire and at least 1.5k out of the rear, and this is all at almost race level miles.
If you are an average rider you can expect at least double that figure.
I'm only intrested in Tubeless Radial tires, nothing else !
Hmmmm...... :rolleyes:
The conclusion of the above is :
Front :
110/60 * 17"
110/70 * 17"
120/60 * 17"
120/70 * 17"
Rear :
140/60 * 18"
150/60 * 18"
Questions :
What size combination is the best for the FZR-600 ?
Explain the riding differences using a 60 profile bike tire compared to a 70 profile bike tire ?
I have only 3,5" rear rim on my bike, What difference does it make compared to a 4,0" rim ?
Explain this a bit more, "you should not be spinning the rear or pushing the front too often" ?
RRBike
moochems
Post by moochems »
With the 3.5 rim I think you'll be needing a 130/60 18 on the rear. the front should be the same however (double check I'm not positive on that figure).
As far as spinning the wheel and pushing the front: You shouldn't be loosing traction on your bike. The thinner tires found on our bikes vs. modern bikes produces a smaller contact patch, meaning that it has less potential traction. However, our engines don't generate too much power so the thinner tires isn't a big deal.
The fact is though, you shouldn't be spinning the rear or pushing the front on anything, Traction is your friend.
One little bottle of spermicidal lube nevery hurt anyone.
1994 Fzr 600 3HE
Ohlins under my ass
Racetech in the forks
Rotella syn 5w40 in the oil pan
Big ol' smile on top
dru86
Level 1.5
Level 1.5
Post by dru86 »
Like everyone else said run a 110/70 up front, also changing the front tyre size will affect your speedo reading.
With the rear I wouldn't run any wider than 140 on the 3.5" wheel, 150 is too wide. I was running Dunlop gpr70s on my 89 fzr600(3.5" rear using a 140/60) with good results.
Lasse
Post by Lasse »
I have done some more research/digging and this is what I have found....
Yamaha FZR-600 OEM equiped tire size from factory :
( 1989 - 1990 )
* Front : 110/70 * 17"
* Rear : 130/70 * 18"
( 1991 - 1999 )
* Rear : 140/60 * 18"
fzraudun
Post by fzraudun »
Bridgestone Bt014 110-70-17 front and 150/60-18 rear on the 1991+ 4.0 rims! 150 is the widest you can go on the 4.0, i think 140 is the widest on tose 3.5 rims. But wheels are cheap on ebay, buy a newer rear rim...
I just bought a set of dunlop gpr alpha 10 that I'm looking forward to testing on the track this summer, BT014s worked marvellous last year! (Artic circle raceway, mo i rana)
milesforster
Post by milesforster »
ok so i hear everyone talking about the 150/60-18 I just bought a 150/70 do you think the wall size will be ok? Ive asked many people but I cant get a good response, is there a big difference in 60s and 70s ? thanx - Miles
