hooking up front turn signals on a 92 FZR 600
FZRrider09
I am looking for answers on how to hook up the front turn signals on a 92 FZR600, I bought the bike in pieces and am now in the process of puting it back together but have no idea where to hook the front turn signals into on the wiring harness, is there a sub harness that I am missing? I know that I am missing the one that hooks the healight into the harness, is there another one that i am missing or did they chop the leads off the harness. Any help? Thanks!
Re: hooking up front turn signals on a 92 FZR 600
yeah there is a sub harness go to the wiki and look at the wiring diagram for 600's
http://fzronline.com/wiki/lib/exe/detai ... iagram.gif
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
space_weazel
Use the wiring diagram, and test as you go, you will probably want an extra box or two of fuses since you will probably bun up a few figuring out which wires you crossed like I did when I re-wired and changed gauges.
If your wiring ends up like mine and when you hit the turn signal and the headlight fuse goes, you need to swap one of the wires on one of the turn signals, which one you have to keep trying or better understand the wiring, I just burned through a few fuses.
Good Luck
Good Luck
