Thanks all
Can I assume that the fittings are all the same down to the three way and on to the calipers?megaloxana wrote:the master is m10x1.25
Yep all the same. Only difference is there's a double banjo bolt at the three way, while all the others are single.space_weazel wrote:Can I assume that the fittings are all the same down to the three way and on to the calipers?megaloxana wrote:the master is m10x1.25
