Front sprocket Nut Torque
- Banshee350
Just curious if any one has the torque spec for the front sprocket nut? I have a clymer manual and it list it as 43ft lbs which seems kinda low to me. Plus it has come loose a couple times even with the lock washer in place. When I took the sprocket off the other day, I flattened the lock washer and was able to take the nut off with my fingers. Anyone with a service manual show something different?
Re: Front sprocket Nut Torque
43ft/lbs(60n/m) is what the factory manual says.
There should be NO way it should come loose with the locktab washer properly installed. Are you sure the washer is engaging the splines?
- Banshee350
The lock washer is fully engaged. It has not come completely loose but would spin back and forth against the lock washer. I will try that torque again and see what happens.
You need to bend forward one section of the lock washer over the nut(towards you).Banshee350 wrote:The lock washer is fully engaged. It has not come completely loose but would spin back and forth against the lock washer. I will try that torque again and see what happens.
- Banshee350
It is bent up against a flat part of the nut. I will try to get is as flush as possible this time. The last time I took it off it was not visibly loose but I was able to take it off with by hand and it was torqued last time I put it on and even used lock tight. Dont get it. Thanks for the torque spec though.
Is this an aftermarket sprocket? Are you sure the nut is torque-ing against the sprocket and not bottoming out on the splines/shoulder?
