hey guys just wondering if anyone can provide some light as to wether a 89 engine with fit into a 92 frame? Rather urgent as i dont want to miss out on a great deal if it is an easy swap.
To clear up the senario, i have a 92 with a blown bottom end bearing. Looking at purchasing a 89 racebike for a steal, just need to know if the engine will swap over.
Cheers heaps people,
Zane
Compatibilty
Re: Compatibilty
Well let's get some details. First, where are you? UK? USA? Austrailia? And are you speaking of the FZR400 or FZR600? Or combining the two?
Re: Compatibilty
ha sorry getting a bit ahead of myself!
Im in new zealand, I assume both the bikes in question were japland imports. The bike that is mine with run bearings is a 92 3tj, would like to take the engine from a 1wg and get it going again. Hope this helps!
Re: Compatibilty
I want to say it might be possible but I'm not for sure. It would seem like it's just a matter of adapting the 1wg to 3tj frame. You could, however, swap in a thundercat motor.
Re: Compatibilty
i could but it would require fabrication, and when someone has a neat bike and a buket load of spares to sell you for dirty cheap, thts my only real option
Re: Compatibilty
The motors mount differently- that's for sure.
Here's an 89 1wg. You see it has lower frame rails and mounts on the bottom as well as up top.
Here is a 3tj like yours...no bottom rails
I'm not sure a if that will work without a bit of modding
Re: Compatibilty
cheers brother
however apparently it will work however the 3tj head must be used for that top engine mount. Anyone contest?
