Rim Swap OR ????
Rim Swap OR ????
O k just curius what it is that i keep here about using a suzuki rim and tire to get a wider shoe and rear stance. is this just a simple rim swap or is there more to it.
cause i have some gsxr rims sitting in my shop collecting dust.
LIVE AS IF YOU WILL DIE-DIE AS YOU HAVE LIVED
Re: Rim Swap OR ????
It's more to give you a 17" rim for better tire choices.
There have been others that have done this, but check out some info here if you're interested: viewtopic.php?f=30&t=753
sounds like there is way more involved then what i want to do deal with right now. i dont want to get into having to mill something. a wider wheel would be nice but i dont much mind a thinner wheel. maybe down the road when everything else is together and im not worrying about the frame i do a swap or mod on the rear wheel or swingarm.
You can go 150/60/18 and some have had the 160 on there but thats stretching it.
