r6 caliper
Locked
DEMORAL1ZE
100+ Posts
100+ Posts
Location: SOUTHEAST MISSOURI--------LAND OF THE FREE, HOME OF THE BRAVE
r6 caliper
Post by DEMORAL1ZE »
is the r6 caliper and master cylinder for the front brakes a direct swap for my 93' fzr ...its an 05 r6
sweekster
Re: r6 caliper
Post by sweekster »
They sure are.
dru86
Level 1.5
Level 1.5
Re: r6 caliper
Post by dru86 »
I'm pretty sure the 05 r6 uses radial mount calipers which won't work, the master will though.
sweekster
Re: r6 caliper
Post by sweekster »
If they are the ones in the pic you have there then those are from an R6s which they will fit just fine.
Re: r6 caliper
Post by thatkid »
sweekster wrote:If they are the ones in the pic you have there then those are from an R6s which they will fit just fine.
actually if you look close they look like they have the holes for radial mounting. Picture is a bit low res to tell.
sweekster
Re: r6 caliper
Post by sweekster »
Yeah..you're rigth
95FZR600
Re: r6 caliper
Post by 95FZR600 »
I dont think the 05 R6 will work. Maybe a better picture will help.
DEMORAL1ZE
100+ Posts
100+ Posts
Re: r6 caliper
kid was right they radial mount....any the auction ended with no bidsssssss
Locked
