All you need is a piece of metal, 16 gauge flat kind you can get from Lowes, a few rubber washers, any bolt/nut combo and a 1/4 wing nut to hold the camera down. Cut the steel about 3 inches, bend at a 90 degree angle. Then drill a hole that will fit the bolt of choice in the flat part on the fairing stay just above the gas tank. Do the same with the piece of steel. Mount it and BAM! You have a camera mount.
Camera Mount
- slayermd
- Level 5.0
Camera Mount
For those of you who want a camera on their bikes when riding, here somthing simple you can do to make it happen.
Reason: Fixed a mispelled word
Re: Camera Mount
Would you mind taking more pics of how it's mounted? Could be useful.
- shredex
Re: Camera Mount
that is how I made my first mount...
its very shaky that way.
I made a mount for the gas cap that works much better!
- megaloxana
Re: Camera Mount
whats with the screen?
- slayermd
- Level 5.0
Re: Camera Mount
So, the bad news. That is the only picture I have of the setup. I was looking through some old pictures of my Fiz and figured I'd share that. Its really simple to make and setup. Here is a sample video as an example.
Sweek, you should edit some of my school papers!
Im guessing you are asking about the camera? Its a Aiptek MPVR+.megaloxana wrote:whats with the screen?
- shredex
Re: Camera Mount
your mount is alot more stable than mine was
heres a vid with my old mount
http://www.youtube.com/watch?v=fDAH_dbt ... re=channel
