Im doing the tail swap r6 style....
- blackeyesandbruises
I got 3 different years lined up, which year is the easiest swap that works the best for my 91?
It consumes me....
Re: Im doing the tail swap r6 style....
Whatever skills you have you make anything work. I have the 99-02 but I have seen 03-05. Its up to you. Any of them will work with modifying.
when you did it did u need any specialty tools?
It consumes me....
a dremel or cutting wheel will help alot
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Sweet so no other major tools need just something to cut and grind with...I like it.
It consumes me....
there is welding involved.
- FasterThanUr
For the 03 - 05 theres a lot of welding that needs to be done.Im not sure about the 99 - 02,but I think it could be done without a welder.
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
What has to be welded? some tabs? I thought it was just shortening the subframe
It consumes me....
blackeyesandbruises wrote:What has to be welded? some tabs? I thought it was just shortening the subframe
The 99-02 you just need a cutting wheel to cut all the old shit off. You will need the under tray or battery tray for the easy install. Do a search on google for "heath's Fzr". his site will show you how to do it. I think most of us followed his tutorial.
Hey I just wanna say you guys on this site are just absolutely great Ive posted topics being the new guy and have never once gotten any slack, Kudos to you guys thank you.
It consumes me....
- FasterThanUr
for the 03-05 you need to cut off about six inchs and reweld it back on top laping it self so theres a spot for the rear to bolt up to.I guess ideally you would want to get some new square tube and remake the back part of the sub.i just recycled what i had cut off and finnished it up with some angle iron that I already had.maybe tomorrow I'll pull the tail apart and start a new thread with a write up of how to do the 03-05 tail swap.
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
Unless you are welding it, I would NEVER put a passenger in the back.
