Rear shock adjustment??
yamaboy
Level 1.5
Level 1.5
Post by yamaboy »
Hey guys..
I'm just wondering what setting do you guys have for the stock shock . I'm 180lbs and it's at 5..Good , bad??
Thanks
1995 ,FZR 600,Factory Pro 1.1Ti Jet Kit, Yoshi slipon,K&N filter,elevation 4200 ft above sea level.
Carb settings: Main Jet 110, Starter Jet 52.5,Needle @ 3rd position,23m Floats,about 3 turns IM Screws.
80's-90's,Rap..music.?? http://www.last.fm/listen/user/unsmenar/personal
megaloxana
Re: Rear shock adjustment??
Post by megaloxana »
The stock shock blows, a worn stock shock blows even more. I'm 140lb and I have it on 5...still too soft (38k mile shock though)
yamaboy
Level 1.5
Level 1.5
Post by yamaboy »
megaloxana wrote:The stock shock blows, a worn stock shock blows even more. I'm 140lb and I have it on 5...still too soft (38k mile shock though)
I only have 10k on my bike though.. I was thinking of changing it to 6 but IDK .. Yeah , It does blow but I don't have a bunch of money to get a new one than modify it.. i guess they don't make those Fox shocks anymore..
megaloxana
fox shocks are done being made. You can run across one on ebay every so often but they go for $300 on average. You can score r6 shocks pretty cheap and modify that.
Check this thread out
yamaboy
Level 1.5
Level 1.5
Post by yamaboy »
megaloxana wrote:fox shocks are done being made. You can run across one on ebay every so often but they go for $300 on average. You can score r6 shocks pretty cheap and modify that.
Thanks for the info
