FZR600 Projection Racing Lowering Suspension Links
chris-seed
Post by chris-seed »
Bought a couple of weeks ago from Projection Racing. I stupidly bought the wrong length of lowering link, fitted them and then realised that my bike was too low (I was using them on a 1988 FZR600 whilst installing an R6 rear shock).
The lowering links are 20mm longer than the standard links. They are in near perfect condition, as I installed them and then took them off the bike straight away.
They were bought from here: http://www.projection-components.co.uk/ ... -977-p.asp
They are 155mm in length from centre hole to centre hole. The holes are 12mm in diameter.
I'm looking for £17.00 including postage to the UK.
Evilchicken0
Level 3.5
Level 3.5
Re: FZR600 Projection Racing Lowering Suspension Links
Post by Evilchicken0 »
Have you aske Projection if you can swap them for a handling charge, they're reasonable people
FZR400RR 3TJ Bimota SB6
chris-seed
I haven't but I assumed that I couldn't swap them due to me actually fitting them to the bike, so they have a couple of very small scratches on them. I might drop them an email though. Although I have ordered new links from Projection and fitted them already.
Evilchicken0
Level 3.5
Level 3.5
I can see the marks, but they could be polished out. As this is mainly a usa site it's unlikely they'll move through here.
Back in the day I drew the plans for TGI Fridays in Stockport
chris-seed
No problem. I'll try them on eBay and see how that goes.
Ah excellent. Small world!
Thanks for the help.
Stig
Level 3.5
Level 3.5
Post by Stig »
If you need bones, I still supply any size in stainless and post worldwide at cost
I also sell on eBay under ID. stigsdump2000
http://www.exup1000.co.uk
