Im lars from holland. I've bought a 1991 fzr1000 a while ago
I like it so. Only the max speed is a bit less than my old bike. But handling / steering ect is really great.
Now after a few weeks i want to ride with it only it dont run...
Its only posible to start with the choke max open And trottle fully closed. Than it fires but nothing more than that. When i touch the choke or the trottle (even a bit) it stops running.
Running no good at all but i think on all the four cilinders.
By the sparkplugtest i remove the plugs out of the motor pull it in the sparkplugcables en try running. Then i will see sparkles nog not hard/strong. On the coils i have good 12volts.
I have a few parts ordert a swap but nothing till now seems to work. Not a change at al.
I have cleaned my bike so i can see everything. Not a plasic is on it. Also the gastank is removed. Between testing i fill the carbs with fuel.
The parts i bought and swapped:
Hal-sensor on the crank
Ignitionbox behind the battery
Battery
Both coils
Spark plugs wires
And al the negative cables cleaned to get a propper connection.
Also cleaned the carbs but no different.
The sparkplugs are wet and smell like fuel
How is the tankmeter to test?
Anybody another ideas?
Thanks,
Lars
