Hey all,
Currently putting the bike back together after months of neglect. A little background, I took the air box off of the carbs, and it seemed to have lifted off effortlessly. The joints/tubes that connect the carbs to the airbox seem rather hard compared to the opposite ends that direct air to the filter itself. They don't seem to be dry-rotted, but are a bitch to install (I thought it would be easier to install the joints onto the carbs first before putting the airbox back on). Is this normal? I wanted to get an experienced opinion before I broke something/started to order parts that I may not need. Pictures below for reference, thanks in advance!
Joint in question:
What I am attempting:
FZR750 air filter joints
Re: FZR750 air filter joints
Might be easier to remount them when you heat them up with a hairdryer as the rubber gets hard during the years but if tehy´re not cracked heat is the way to get them flexible again for a little time which should last enough to remount them again. Mounting them first to the carbs and reheating with the hairdryer afterwards to remount them to the airbox is a usual way for old rubber-joints
Its also possible that a little bit of motoroil might be helpful enough so that heating is not really neccesary, so i would try it with some drips of oil at first and if thats not working well enough then dry them with a kitchenpaper or an old piece of textile and try the heating-method.
Completely forgot to thank you for this! Honestly, I haven't been too adamant about getting this thing back together and it's still in pieces.TomcatMJ wrote:Might be easier to remount them when you heat them up with a hairdryer as the rubber gets hard during the years but if tehy´re not cracked heat is the way to get them flexible again for a little time which should last enough to remount them again. Mounting them first to the carbs and reheating with the hairdryer afterwards to remount them to the airbox is a usual way for old rubber-joints
