I bought a 92 FZR600 a few months ago and finally got it running after months of trouble shooting and now that I have the bike running I need to figure out why the bike has all open circuits even with the key off. Im thinking it might be a relay but cant figure out which one (if it is) Every once in a while it will all be normal and run off the key but then out of nowhere its back to its usual BS.
Dose anyone out there have any ideas on where to start looking?
Any info would be much appreciated.
Thanks again in advance.
92 FZR600 Electrical issues
Re: 92 FZR600 Electrical issues
It SHOULD be open circuit with the key off. If the circuits are open, it shouldn't run. What are you trying to say?
Basically with the key off and out, the bike will still run. The only way to shut everything off is the remove the battery. Ive run a testlight over every wire i could find.
