Front Brake Lever
Fartblood
Level 4.5
Level 4.5
Front Brake Lever
Post by Fartblood »
Does anyone know if the adjustable span front brake lever from an FZR600R will fit the my FZR600 3HE?
Cheers,
Rich.
Luke-a-Tron
Re: Front Brake Lever
Post by Luke-a-Tron »
I think it will. I just put a YZF 600r master cylinder which has the adjustable lever. I'm having all sorts of issues with the remote reservoir being in the way, or not staying or put or blah blah blah. So I'm thinking about going back to my original master cylinder and just taking the lever. I held the two up next to each other last night and as far as I can tell, it should work. The only potential problem I didn't think about until just now is that the brake light switch is a little different between the two. I don't know if the tab that depresses it is in the same place from one lever to the other. I'll have to look into it.
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
OK, cheers LT.
