Hi thanks for reply's
Mine is an 89 exup so must be different
I think Ive worked it out?, the pipe is a breather pipe for the sump. The sump cant breathe through the casting hole due to the oil in clutch. The breather goes into the clutch case air/oil separator which also connects to the crank case breather at top of case.
So the air is drawn from the sump and clutch ( the air is separated in the clutch case labyrinth ) into the crank case to the carbs.
Oil from clutch labyrinth will return via pipe as this needs to be sealed from oil in clutch case.
Hope this make sense ?
