FZR600 3HE rear wheel in 1WG FZR 400?
FZR400 Forum
neroneuman
Post by neroneuman »
Hello Guys,
Can I put the FZR600 3HE rear wheel on a FZR400 1WG?
I was looking at the wheel bearings and all balls brand have different numbers for the rear wheel bearings for the 400 and 600.
Part Number 25-1232 for FZR 400 rear wheel and Part Number 25-1238 for FZR 600 rear wheel.
Another thing is there a difference between the white colors used in FZR 400 and 600?
I see the white color used on the 400 is more bright compared to the 600 or is it me?
Regards,
Sanjeevi
Evilchicken0
Level 3.5
Level 3.5
Re: FZR600 3HE rear wheel in 1WG FZR 400?
Post by Evilchicken0 »
The 600 rear wheel will fit into the 400 swingarm, the difference in the bearings is outside dia so the spindle will still fit. The brake disc is different (wider dia) so you'll need the calliper and hanger.
I don't know why Yamaha would change the paint from one to another model, maybe the 400 wheels have been repainted ? I've used Mr Muscle limescale remover on a set of white wheels which seemed to work well.
FZR400RR 3TJ Bimota SB6
neroneuman
hmm, Sounds good.
Thanks Bud.
