Need help with radiator brackets
Hey guys, it's been a while... Still working on resurrecting my 1997 FZR 600. It was an abandoned project. Motor had a spun bearing so I am putting a 99 YZF 600 motor in the 99 frame. Everything has pretty much been plug and play except the radiator. The 99 mounts on the top while the 97 mounts on the side. Does anyone have any suggestions for mounting the 99 radiator in the 97 frame? Any pics would be appreciated.
Re: Need help with radiator brackets
It's just bent light-gauge aluminum, so some lengths from the local Metal Supermarket should help.
Bear in mind that the trigger wheel on the YZF is not compatible with the FZR TCI box. Not only will you need the YZF600 TCI, you'll also need the carbs with TPS and a fuel level sensor, OR dummy resistors to make the TCI think everything is there. I can offer a plug'n'play adaptor harness, to connect the YZF TCI to the FZR harness. I can provide leads or dummys for the fuel and TPS, depending on what you have.
I may be interested in the adaptor harness. I'll take inventory of what I have.
