Exactly as he title says, I am looking for the plug and a few inches of wire from a stator for the FZR600. Mine appears to have had some arcing from a bad connection and is a little melted. Though it was charging decently, I'd rather fix it right than get stranded somewhere.
Let me know if anyone has a junk one laying around that they wouldn't mind chopping up.
WTB Junk Stator/alternator (specifically the wiring)
Forum rules
Re: WTB Junk Stator/alternator (specifically the wiring)
If you can't find someone to buy used, you can buy it new from these guys.
Wow, that's perfect. Thanks much! was looking online and none of the plugs I looked at seemed quite right (though a lot were close) which is why I went looking for a junk unit to scavenge. This is probably better than what I was planning on doing.DonTZ125 wrote:If you can't find someone to buy used, you can buy it new from these guys.
Tell Alex, "Don from Canada says hi!"
