1992 fzr 1000 37000 miles
Hello all asforementioned I am going to do some pre ride maintenance to my bike I need to know the intake exhaust valve clearances and the"correct" float height adjustment also what's the most miles I can expect out of this bike before major repair with normal pm thanks
Re: 1992 fzr 1000 37000 miles
valve clearance are in the factory workshop manual that you can download free from my place
http://www.exup1000.co.uk/tech/fzr1000r/index.html
The floats can be set using info in the following link
http://www.exup1000.co.uk/tech_info_are ... height.htm
as for major work....if you mean engine apart then it depands on what sort of life and maintenance schedule the bikes had/having. Some of these bikes go 70K with nothing more than valve clearances and frequent oil changes and of course run of the mill service procedure. Treat them right and they'll look after you
Thanks for the reply
