Bike sat for a good bit. So i decided to adjust the carbs(mixture and sync) because it was running pretty rough. Did 1-3 just fine...goto 4 and no matter what direction i turn the screw it did nothing. temps around 150(so lean right??). My guess is carb rebuild should be my next step correct.
I wasn't sure if there is a correct order but my original plan was to get the mixture right then sync. But i chose not to sync any of them with the "dead" cylinder. Do you think i should sync and try again or rebuild carb and go from there??
mixture screw doing nothing?
91 fzr 600
r6 blue dot swap
r6 vrr
r6 blue dot swap
r6 vrr
Re: mixture screw doing nothing?
150 would be rich. A lean condition causes it to run hotter. However I suspect there may be other issues at play. I would pull the carbs and give them a thorough cleaning, check the float heights and reassemble.
