Dyno jet questions
Bmansfzr600
Dyno jet questions
Post by Bmansfzr600 »
Hi all. Just got a dyno jet jet kit for my fzr660r
( yes it has the 660 kit in it). It has pod filters ,cams , heads ford coil pack, wires, full exhaust, e3 plugs. Put the dyno jet kit in and now runs like crap. Way rich. Was wondering if anybody has a similar setup and what they did for the carb tune. I did what the directions in the kit said. Any help is greatly appreciated.
Thanks. Brian
ragedigital
4000+ Posts
4000+ Posts
Re: Dyno jet questions
Post by ragedigital »
What RPM or throttle position are you having issues at?
There are different adjustments for every range.
Bmansfzr600
It's in the upper rpm's. around 8,000 at half throttle or more. According to ur chart I need to change main jets. Dyno jet said to put the 130's In. So I did. But I had 115's in b4 the accident and it ran good so I'm thinking I will put the 118's in that came in the kit.
Thanks. Brian
Contrary to popular belief, nobody owes you anything!!!
