It appears I have the fairly prevalent clutch push rod oil leak, #13 appears to be the correct part per bike bandits' shematic? Do you recommend any other parts beyond that?
Clutch is working fine, just have oil leaks.
http://www.bikebandit.com/houseofmotorc ... #sch132344
Also, well I'm there should I replace part #3 that seals the shifter shaft? Is that known to go bad as well?
http://www.bikebandit.com/houseofmotorc ... #sch128767
Can someone please advise, I don't want to order the wrong parts.
Thanks,
Kenny
Another clutch push rod oil leak
Kenny two guns
1995 Yamaha FZR600
1992 Kawasaki EX500
1992 Kawasaki EX500
