What's the best VRR to buy that fits the standard plug in UK
CadburysBoost600
Post by CadburysBoost600 »
It's for my '90 FZR600. M & P list 2 different ones, Yambits just list the stock one.
I did a search of the forum, and it mostly seems to find stuff about 5 pin and 6 pin stuff, mines a 4 pin, and I don't really want to have to order a harness from the US, I'd just like to fit the new part ASAP
M in KC
Re: What's the best VRR to buy that fits the standard plug i
Post by M in KC »
CB, you don't necessarily need a separate harness. All you need are five fully insulated female electrical spade connectors similar to the one below.Image
Then all you need to do is mount your new VRR. Here is how I did mine. Others have managed to mount them with the electrical connections pointing down to minimize moisture getting into the connections. I've had mine setup this way for a long time without issue.
This VRR is from the +95 600 FZR or R6's here State-side.
M in KC
Post by M in KC »
I probably should of just posted this first.
http://fzronline.com/wiki/doku.php?id=r ... conversion
CadburysBoost600
http://www.mandp.co.uk/productinfo.aspx ... ectrosport
This seems to have a heat sink with
