At first I was thinking about buying a yzf motor. Then dropping the crack shaft, fly wheel and the generator in to if from the fzr. I realize that it would take a 3 mm base, changing the wiring a bit, and probably swapping the rear end to get the chain straight. Then there's the crank seal that I can't seem to find. All the leads to finding one in the old threads are dead.
Then I like the way RR did his with just changing the cylinders and pistons. Then having the rods honed to fit the pistons. I like how simple and cost effective that is.
I'm pretty sure I'm going the simpler route, but just to make things a little more complicated I think I'll try to find a set of the fazer rods. Though I don't know which year I am supposed to look for, or a way to figure it out.
Though I've worked on vehicles, I have always stayed away from engine work until now. I don't mind criticism and its hard to hurt my feelings, so if you guys think I'm batching something let me know.
I just want to make sure I'm not missing something simple with my lack of experience.
