fzr1000 waterpump problems mixing oil and water ?
Hi guys can my waterpump or his seals be the problem that my oil and water is mixing the waterpump is shot water dripping from the weep hole
Re: fzr1000 waterpump problems mixing oil and water ?
Yup. Your seals are shot, and you may be contaminating your oil leading to engine damage.
Ok thanx alot don dont wanna take of the headgasket again coz i know its good no bubbles in the radiator no white smoke from the exhaust will take out the plugs to check them so it can bet the waterpump seals that mixes the water in the oil
