I posted this over on FZRarchives.com but after a couple of days I haven't gotten any responses.
I have a 91 FZR600 that I started work on years ago and then life happened. So it's been in storage for quite some time. Now that my bro and I have some time we're thinking of getting her back into fighting shape. Lots of things need to be done/addressed but one of the main reasons for taking it off the road was a valve adjustment and a partial tear down to address some rust on the frame. I believe the previous owner wasn't paying attention to the battery or the overflow tube from the battery. It leaked and the hose was close to the frame and it's got some rust. Nothing that has compromised the strength but I need to fix it. So, long story short, here's my first question.
Just before having to store it, I replaced the clutch and put a shift kit in it. When I was installing the spring I believe my tool slipped and poked a hole in a gasket that is just below where the spring installs. I don't have any photos, yet. I'm at work and am not near the bike to do so. I'm just curious if anyone knows what I'm talking about, what this gasket is and if this is a problem. It's been a long time since I've laid my eyes on the hole but I think it separated the clutch housing and the oil pan? Does this sound right?
Thanks in advance, guys and gals.
Gasket question
toothlesrooster
Gasket question
1991 FZR600
Re: Gasket question
If its separating the clutch from the oil pan it will allow oil to escape from the clutch at a much faster rate than the normal speed of it coming out through the drain tube. I think to protect the clutch oiling you may have to replace the gasket.
But its my 2 pennies and I've been wrong before. BTW the US is huge, a region, or state may allow a member near you to drop by and give you a look see.
toothlesrooster
Re: Gasket question
Thanks Rooster. That's what I was thinking as well. I need to take the clutch cover back off and look at it closer to see which gasket it is. I did update my location info as well. Thanks for the tip and help!
1991 FZR600
